B&W 800 D3 Series Diamond
Unread post #1 by Gojakla » Sun Apr 03, 2016 9:41 pm
Official Site
OVERVIEW
802 D3
Capable of delivering pristine, natural sound that will leave you speechless.
Continuum Cone
The Continuum cone delivers pristine midrange performance by effectively negating the break-up behaviour that can adversely effect this all-important part of the spectrum.
Plinth
The innovative plinth provides an incredibly solid base for the 800 Series Diamond. The spikes are ideally positioned below the cabinet, and ingenious engineering allows you to switch between castors and spikes with ease.
Solid Body Tweeter
The Diamond dome tweeter is housed in a solid piece of aluminium. This mechanically inert structure provides an incredibly rigid platform from which the tweeter can deliver crystal clear sound.
Matrix
Bracing is essential in keeping a speaker stable, so the character of instruments comes through cleanly. Developed using computer modelling and constructed from wood ply with metal reinforcement, Matrix offers the ultimate in bracing.
803 D3
A completely new speaker, and the most compact headed model Bowers & Wilkins has ever made.
Reverse Wrap Cabinet
Relocating the curve of the cabinet to the front has a double benefit – it allows stronger joins at the back, while also helping sound dispersion across the curve of the baffle.
Continuum Cone
Turbine Head
The Turbine head is the ideal shape for sound dispersion, while its internally ribbed, aluminium construction ensures that it is acoustically inert.
Diamond Dome Tweeters
Incredibly light, yet unbelievably rigid, Diamond is the ultimate tweeter material. Delivering the most revealing, natural treble you will ever hear.
804 D3
Delivers incredibly high-performance sound in a traditional loudspeaker form with a smaller footprint.
Matrix
Continuum Cone
Aerofoil Cone
The Aerofoil cone’s variable thickness provides added strength where it is needed to maintain its pistonic shape, delivering rock sold bass.
805 D3
The only loudspeaker of its size to feature studio-grade technology in the form of a Diamond dome tweeter.
Solid Body Tweeter
Continuum Cone
GALLERY
Re: B&W 800 Series Diamond
Unread post #2 by Dr Pan K » Sun Apr 03, 2016 10:15 pm
Είχα την ευκαιρια να ακούσω για λιγο τα 803 στην πρόσφατη επίσκεψη μου στο Stereo Exchange της NY. Τα συνοδα ηταν όλα SimAudio Moon Evolution series (750 DAC - Transport και 600i Integrated amp).
Ο ήχος ευχάριστος, λεπτομερείς οσο χρειάζεται και με χαμηλούς χρωματισμούς. Σημαντικό νομίζω οτι ο ενισχυτής που οδηγούσε τα B&W δεν ηταν κάποιο θηρίο, αποδίδει 125W/8Ohm> 250W/4Ohm οπότε ισως η νεα γενιά των εγγλέζικων ηχείων να μην εχει τις αρκετά μεγάλες απαιτήσεις σε οδήγηση που ειχαν οι προηγούμενες. http://www.simaudio.com/en/product/15-i ... ifier.html
Περισσότερες εντυπώσεις μολις μπορέσουμε να τα ξαναακουσουμε, πιθανόν στο Μόναχο.
stereo exchange.jpg (48.41 KiB) Viewed 11311 times
Re: B&W 800 D3 Series Diamond
Unread post #3 by Dr Pan K » Tue May 10, 2016 11:40 pm
Ακούσαμε λοιπόν και το πολυαναμενόμενο 800D3, πριν 3 ημερες στο Μόναχο, στο ξενοδοχείο Bayerischer Hof όπου έγινε και η πρώτη επίσημη παγκόσμια παρουσίαση απο τους μηχανικούς της B&W στην δημοσιογραφική κοινότητα.
Το ηχείο εξωτερικά μοιαζει πολύ με το μικρότερο 802 D3 αλλα οπως μας εξηγησαν οι μοναδες των χαμηλων εχουν επανασχεδιαστεί απο την αρχη. Η B&W απ οτι μας ειπαν δεν εχει σκοπο να ξαναχρησιμοποιήσει μια μεγάλη μονάδα και η κατεύθυνση της εταιρίας θα ειναι προς τις 2 λιγο μικροτερες για να πετυχει χαμηλότερη παραμόρφωση. Το υλικο των μοναδων ειναι πολυ εντυπωσιακό, ενα σάντουιτς απο κατι σαν πλεγμένο ανθρακονημα με εσωτερικο απο αφρο, παρα πολυ ελαφρύ και ιδιαίτερα άκαμπτο (το πιάσαμε στα χερια μας και ειναι όντος σχεδόν αδύνατον να το στρεβλώσεις).
Η καμπίνα εχει και αυτη επανασχεδιαστεί απο την αρχη, εχει ενισχύσεις απο αλουμίνιο και ατσάλι, ο κώνος των μεσαίων ειναι όλος απο χυτό κράμα αλουμινιου ενω ο ναυτίλος του tweeter ειναι απο αλουμίνιο επεξεργασμένο στον τόρνο. Σαν κατασκευή εχει ξεφύγει πολυ απο την τελευταία γενιά των Nautilus και Diamond, ειναι πρακτικά ενα πολύ πιο σύγχρονο σχέδιο.
Η εταιρία εχει μεγεθύνει κατα 50% τις διαστάσεις του εργοστάσιου της καθως περιμενει να εχει πολυ μεγάλη παραγωγή (η ζήτηση ειναι ηδη τεράστια) παρα την τιμη των 30Κ ευρώ στην Ευρώπη (και αντίστοιχη στην Αμερική και Ασια).
Unread post #4 by Dr Pan K » Wed May 11, 2016 12:08 am
Μας δόθηκε η δυνατότητα να ακούσουμε τα 800ρια μαζι με Classe (CA-M300 και CP-800) σε ενα δωμάτιο με ελάχιστο room treatment και μάλλον ακατάλληλες διαστάσεις. Ήμασταν με την πλατη πολυ κοντα στον πίσω τοιχο, τα ηχεια είχαν τον ελάχιστο απαιτούμενο χωρο για να αναπνεύσουν.
Παρολαυτα πρέπει να πω πως έσκισαν σχεδον σε ολους τους τομεις. Χαμηλο γρήγορο, με αψογη περιγραφη, στακατο, οπως πρεπει δλδ. Μεσαίες συχνότητες καλες, ισως λιγο μπροστά σε σχέση με τις χαμηλές, ουσιώδεις και χωρις χρωματισμούς. Ψηλες με έκταση και λεπτομέρεια, μονο ψεγάδι κάποια συριστικά που τσιμπήσαμε σε 2 απο τις 5 ηχογραφήσεις του demo.
Στην ουσία το ηχείο θα κριθει για αυτα τα συριστικά, αν ηταν κακη επιλογή μουσικης ή συνοδών θα φανει στο άμεσο μέλλον. Τα 30Κ ευρω μπορει να φαντάζουν πολλα για τον μεσο Ελληνα της κρισης αλλα στο εξωτερικό θα πουλήσει σαν ζεστο ψωμί. Πολλα high end ηχεια της εκθεσης με σαφως μεγαλύτερες τιμες απογοήτευσαν σε σχέση με τα πιο εμπορικά B&W 800 D3. Αν βάλουμε μεσα και παραγοντες οπως η εμφάνιση και το φινίρισμα (άψογα) ή το δικτυο - after sales support κτλ τοτε η επιτυχία ειναι μάλλον δεδομένη.
B&W_20115_800 new_high angle_FIN.jpg (187.78 KiB) Viewed 11215 times
Unread post #5 by Gojakla » Wed May 11, 2016 12:59 am
Ερωτας...
[inlove]
Unread post #6 by Chris1967 » Wed May 11, 2016 8:56 am
Αν εξαιρέσεις το θέμα των συριστικών... εγώ έχω πάθει την πλάκα μου... το θέμα είναι ότι πρέπει να αφήσω τον θείο και να πιάσω το λόττο :lol:
Σταύρος Τρύπης
Unread post #7 by Σταύρος Τρύπης » Wed May 11, 2016 2:44 pm
Αν σας περισσεύει κανένα σε μαύρο χρώμα από power buy, ενημερώστε με αμέσως!
Το αγοράζω χωρίς ακρόαση... :)
Unread post #8 by Dr Pan K » Wed May 11, 2016 3:18 pm
To μαύρο ειναι ερωτευσιμο..
(οι φωτογραφίες ειναι απο το επίσημο press kit που μου έδωσαν στην παρουσίαση)
B&W_20115_800 3FIN.jpg (226.13 KiB) Viewed 11192 times
B&W_20115_800cal_rear FIN.jpg (168.38 KiB) Viewed 11192 times
Unread post #9 by Dr Pan K » Thu May 12, 2016 6:20 pm
Μια πιο εκτενής αναφορά απο το Part Time Audiophile
Unread post #10 by DomieMic65 » Fri May 13, 2016 8:07 am
Πραγματικά η μεγαλύτερη εταιρία ηχείων παγκοσμίως!!
το "μικρό" 805 σε τι κατηγορία τιμής παίζει;
