Stax SR-009S
Stax SR-009S
Unread post #1 by Dr Pan K » Tue Apr 24, 2018 12:39 pm
Κυκλοφορήσαν τα ανανεωμένα STAX SR-009S, με πληρως ανασχεδιασμένη μεμβράνη. Μολις η Orpheus θα εχει ζευγάρι για δοκιμή θα φροντίσω να το πάρουμε..
Sound element with new fixed electrodes
If the fixed electrode becomes infinitely thinner, the air resistance will be de- creased and the permeability of sound waves will be improved. On the other hand, thinner electrodes are poor in rigidity and suffer from vibrations of their own and the sound becomes muddy.The SR-009S evolved further the electrode established in the SR-009 as the integration of presenttechnology.
The edges of electrode hole were smoothened through after-etching processing to reduce air resistance, and the permeability of sound has been much more improved. Moreover, gold plating processing with large specific gravity further decreased the electrode vibration. Finally, the sound clarity has been achieved by reducing the resistance of electrode itself.
●Type:push-pull electrostatic large circular sound element, open-air type enclosure
●Frequency response:5 – 42,000Hz
●Electrostatic capacitance:110pF (including cable)
●Impedance:145kΩ (including cable, at 10kHz)
●Sound pressure sensitivity:101dB / input 100Vr.m.s. / 1kHz
●Bias voltage:DC580V
●Right/left channel indication: Golden solid line (left) and dotted line (right) on the cable
●Earpad:Genuine leather (skin touching portion), high-quality artificial leather (surrounding portion)
●Cable:Silver-coated 6N (99.9999%) OFC parallel 6-strand, low-capacity special wide cable, 2.5m full length
●Weight:583g (including cable), 441g (without cable)
009S side.jpg (61.11 KiB) Viewed 3207 times
009S front.jpg (43.3 KiB) Viewed 3207 times
009S diaphragm.jpg (76.14 KiB) Viewed 3207 times
009S brochure.jpg (91.43 KiB) Viewed 3207 times
https://stax-international.com/products/sr-009s/
Re: Stax SR-009S
Unread post #2 by AthanasiosL » Tue Apr 24, 2018 1:39 pm
Σε τι κατηγορία εντάσσονται αυτά Παναγιώτη απο πλευράς κόστους - απόδοσης?
Re: Stax SR-009S
Unread post #3 by Gojakla » Tue Apr 24, 2018 1:42 pm
Αν έχουν χαμηλό, θα είναι -άλλο ενα- dream headphone για μένα.
Re: Stax SR-009S
Unread post #4 by Dr Pan K » Tue Apr 24, 2018 1:48 pm
AthanasiosL wrote:Σε τι κατηγορία εντάσσονται αυτά Παναγιώτη απο πλευράς κόστους - απόδοσης?
Στην κορυφη της κορυφης. Σε ολα ;-)
Tα προηγούμενα 009 ηταν απο θεμα τονικότητας αχτύπητα (γενικα η τεχνολογία των ηλεκτροστατικών ακουστικων εχει πολυ χαμηλη παραμόρφωση στις μεσαίες και ολα -STAX, Kingsound, HiFiMan- εχουν πολύ καλες χροιές).
Χρειάζονται ομως ενα ειδικο κύκλωμα (charger) που δημιουργεί την σταθερή ταση για να λειτουργήσουν (ειναι ηλεκτρομαγνήτες και οχι σταθεροί μαγνήτες), οποτε αυτο ανεβαζει το κοστος. Η STAX πουλάει διάφορα μοντελα charger/ amplifier σε solid state και λαμπατο σχεδιασμο, το μεγαλο λαμπατο ειναι εξαιρετικο (και το κοστος αυτου επισης δεν ειναι χαμηλο, πακετο με τα ακουστικα νομιζω ξεπερνά τις 8Κ ευρω). Φυσικά υπάρχουν και πιο οικονομικά μοντελα αλλα εδω μιλάμε για το απόλυτο.
