Allo DigiOne Signature (RPi SPDIF HAT)
Unread post #1 by DomieMic65 » Tue Oct 02, 2018 8:48 pm
Η Allo έχει βαλθεί να μας τρελάνει... και να μας τη σπάσει εμάς που πριν όχι από πολύ καιρό πήραμε το απλό μονδέλο...
Allo DigiOne Signature το διόροφο...https://allo.com/sparky-eu/digione-signature.html
Βάλε και τα εξτρα τροφοδοτικά που χρειάζεται νομίζω πως ξεφεύγει λίγο η μπαλίτσα!
Τέλος πάντων...
Our regular DigiOne has no equal.
In our quest for digital perfection we asked how we can improve the design and give you the ultimate DigiOne.
First, we decided to use more board space (we are using 2 boards), the PCB area increased 220%. First board is the “dirty side” and top board has the “clean side”. With the extra space, we used the best decoupling capacitors (film) on everything that’s important (clocks, buffers, flip flops). Also, with this extra space we added a supercap on the “clean side” so most of the electrons come from this onboard “buffer” (there is so much power onboard that DigiOne Sig can run a few seconds without any power attached to the clean side).
We also decided to use 2 power supplies. The “dirty power” needs 5V /2-3A (RPI power). The “clean side” needs about 100mA and accepts from 5V to 6V. You can use anything on it, linear power supply or pure batteries power.
Thirdly, we changed the clocks to the latest from NDK (ultralow jitter SDA) that have lower phase noise than the previous generation.
Re: Allo DigiOne Signature (RPi SPDIF HAT)
Unread post #2 by Dr Pan K » Tue Oct 02, 2018 9:38 pm
Ωπ, εδώ ειμαστε. Πάω να βρω χαρακτηριστικά..
Unread post #3 by Dr Pan K » Tue Oct 02, 2018 9:42 pm
It’s a "re-clocker". The unit has its own clocks so it does not rely on the jittery RPI clocks
It's galvanically isolated. The clean board is isolated (ground and signals) from the dirty side
It needs 2 PSUs, one for 5V/2A-3A (RPI) and a second power 5V to 6V 100mA. We do recommend the cleanest power supply possible (batteries, linear but even a good SMPS will work)
Old driver is compatible for both units (chose DigiOne on your favorite player)
Measured jitter has decreased further, less than 400fs (tested at buffer)
Output is coaxial/BNC and rise/fall time is 1ns and voltage level is exactly as per guidelines (550mV on coaxial) measured at end of transmitting cables
Includes 2 x DC to Type C Adapter Cables
Τιμή 250 ευρώ, έξοδος μόνο μία ποιοτική Coaxial. Καλή περίπτωση δεδομένου ότι έχει και reclocker αλλά δεν θα το αγόραζα χωρίς δοκιμή. Και φυσικά ζητάει και 2 τροφοδοσίες που αυξάνουν το κόστος. Το jitter χαμηλό αλλά όχι και στα τάρταρα, το Rockna πχ που είναι σχεδιασμένο πάνω από 3 χρόνια έχει πιο χαμηλές τιμές..
Unread post #4 by DomieMic65 » Wed Oct 03, 2018 6:46 pm
Ναι ακριβώς για αυτό λέω και εγώ πως ξεφεύγει λίγο το πράγμα... με τέτοιες τιμές η Allo μπαίνει σε χωράφια "κανονικών" εξωτερικών συσκευών και πλέον η όποια αγορά θέλει ακρόαση συν την όποια έξτρα αναζήτηση και κόστος για τροφοδοτικά κλπ... ακριβώς το ίδιο ισχύει και για τοn νέο της DAC το Katana!
Απ' την άλλη όλη αυτή η DIYoLego κατάσταση μου ασκεί μια γοητεία είναι η αλήθεια! :)
Το θέμα είναι όμως ότι σε τέτοια κόστη πλέον δεν πρέπει να υπερνικά ο γκατζετάκιας που κρύβουμε μέσα μας αλλά να αναζητάμε ουσία...
Unread post #5 by Dr Pan K » Wed Oct 03, 2018 7:14 pm
Ε ναι, με τα τροφοδοτικά και όλα κομπλέ μιλάμε για πάνω από 300 ευρώ, και μάλιστα μονο για μια coaxial έξοδο. Αν έβγαζε και ποιοτική USB θα ήταν πιο πασπαρτου συσκευή.
Εξάλλου περιμένω να ακούσω και το reclocker που έχει σχεδιάσει ο Lemon με την παρέα..
Unread post #6 by DomieMic65 » Fri Oct 05, 2018 3:02 pm
Dr Pan K wrote:Ε ναι, με τα τροφοδοτικά και όλα κομπλέ μιλάμε για πάνω από 300 ευρώ, και μάλιστα μονο για μια coaxial έξοδο. Αν έβγαζε και ποιοτική USB θα ήταν πιο πασπαρτου συσκευή.
Έχουν στον κατάλογό τους και ένα special USB HAT αλλά προορίζεται μόνο για ένα δικό τους board το Sparky το οποίο τρέχει μόνο Volumio ή DietP (και μέσω αυτού διάφορα OS)i!!!
Unread post #7 by Dr Pan K » Fri Oct 05, 2018 3:33 pm
Το έχουν πιάσει το νόημα, πάνε να κλειδώσουν τους χρήστες στο δικό τους οικοσύστημα. Προσωπικά δεν τσιμπάω, θα έπρεπε να έχουν κάτι τουλάχιστον ισχυρότερο του Odroid C2 και φυσικά να τους υποστηρίξει ο Tuxx, γιατί χωρίς Archphile δεν ζω.
Άσε που αν αρχίσει να ανεβαίνει το πακέτο στα 500 ευρω για βασική πλακέτα και hat (χωριά τροφοδοσίες και κουτιά) μπαίνουμε στα χωράφια των εμπορικών λύσεων (με πολύ καλύτερο interface, μεταπώληση, support..)
Unread post #8 by DomieMic65 » Sat Oct 06, 2018 2:22 pm
Είναι δυνατό το board τους και μαζί με το USBridge ακόμα πιο πολύ, αλλά όπως λες και το κόστος ανεβαίνει και κυρίως έχει πολύ περιορισμένη υποστήριξη ... χωρίς Archphile no go!!!
Παρ’ όλα αυτά το DigiOne (Sig) παίζει κανονικά με Archphile...
hunter
Unread post #9 by hunter » Thu Dec 20, 2018 1:13 pm
Κατοχος κι εγω του digione signature δηλώνω απόλυτα ευχαριστημένος. πολύ καλό!
Με ποιο coaxial παιζετε εσείς?
Unread post #10 by DomieMic65 » Sun Dec 23, 2018 7:25 pm
hunter wrote:Κατοχος κι εγω του digione signature δηλώνω απόλυτα ευχαριστημένος. πολύ καλό!
Μάλλον είσαι ο μόνος εδώ!
Εγώ έχω το απλό.
Καλορίζικο!!!
Για πες λίγες εντυπώσεις παραπάνω.
Με ποιο λειτουργικό παίζεις; Τι χρησιμοποιείς για την τροφοδοσία του;
Καλώδια έχω δύο.
Ένα Vovox RCA/RCA κ ένα κινέζικο BNC/RCA με καλώδιο και βύσματα Canare
