Straight Outta Factory!
Unread post #1 by Dr Pan K » Tue May 31, 2016 10:20 pm
Straight Outta Factory.jpg (409.24 KiB) Viewed 77736 times
Ένα νήμα για τα νεα μοντέλα που ανακοινώνονται απο τους κατασκευαστές.
Wired 4 Sound
Statement stereo power amplifier
class D 2x750/8, transformer coupled input!
image courtesy of John Darko
Berkeley Audio Design
Alpha DAC Reference series 2, 24/192
MSRP $19.500, owners of Alpha 1 can upgrade for 3.5K
Wilson Yvette
Unread post #2 by Dr Pan K » Tue May 31, 2016 10:55 pm
Wilson Audio
Yvette 3 way speaker (will replace Sophia 3?)
Bryston BLP-1 Turntable
Unread post #3 by Dr Pan K » Wed Jun 01, 2016 7:51 pm
Features high torque motor
driven by a proprietary pulse width modulation (PWM) power supply (BTP-1)
Delrin platter - Titanium tonearm
MSRP $3995
Aavik M-300
Unread post #4 by Dr Pan K » Wed Jun 01, 2016 10:40 pm
Aavik
M-300 mono power amplifier
aavik mono 300.jpg (75.85 KiB) Viewed 77700 times
Re: Straight Outta Factory!
Unread post #5 by BityaBit » Wed Jun 01, 2016 10:52 pm
New Meridian Ultra Dac.
The Meridian Ultra is a 384kHz/24-bit dedicated DAC capable of playing virtually any recording format including DXD, DSD64 and DSD128 (DoP), and MQA.
https://www.meridian-audio.com/products ... ultra-dac/
The world’s first public showing of the Meridian Ultra DAC will take place at the 2016 T.H.E. Newport Show, June 3-5, in the Sunny Components Room 1203.
Find out more at http://www.meridian-audio.com.
Product Page: Ultra DAC
Suggested Retail Price: $23,000
Front angle no shadow.jpg (118.98 KiB) Viewed 77698 times
Bittner Tonmeister 500
Unread post #6 by Dr Pan K » Sun Jun 05, 2016 10:46 pm
Bittner
Tonmeister 500
250Watt/8 in push pull configuration
20x KT120, 2x 6N30, 2x 6N1P, 2x 6550
49.000 euros
bittner 500 front.jpg (141.88 KiB) Viewed 77669 times
bittner 500.jpg (178.72 KiB) Viewed 77669 times
http://highend.bittner.audio/en/products/tonmeister-500/
Veracity Chrysalis DAC
Unread post #7 by Dr Pan K » Sun Jun 05, 2016 11:13 pm
Veracity
Chrysalis DAC
5.690GBP
https://veracityaudio.com/products/vera ... ing-remote
Helius Designs Viridia Turntable
Unread post #8 by Dr Pan K » Sat Jun 11, 2016 10:31 pm
Helius Designs
Viridia Turntable
$6500 (without tonearm)
Helius Designs Viridia.jpeg (809.75 KiB) Viewed 77638 times
http://www.heliusdesigns.co.uk/
Total DAC d1- core
Unread post #9 by Dr Pan K » Sat Jun 11, 2016 10:52 pm
Total DAC
d1- core
Οι ιδιες αντιστάσεις και FPGA, μικρής έκτασης cost saving και τιμη...
4700 euro
-192KHz asynchronous Xmos USB, optical, RCA and AES-EBU digital inputs, selectable from a remote control.
-44.1KHz, 48KHz, 88.2KHz, 96KHz, 176.4KHz and 192KHz, 16 to 24 bit formats supported.
-as an option, DSD (DoP standard) supported on all the digital inputs.
-embedded custom clock with anti-jitter FIFO memory.
-3.0Vrms max RCA. 6.0Vrms max balanced XLR output.
-volume control, adjusted by a remote control and an OLED display, works for all inputs, not only USB.
-phase polarity selected by remote control.
-non-oversampling DAC compensation filter activated or disactivated by remote control.
-display switched off by remote control or automatic.
-R2R DAC technology using 0.01% VAR Bulk Metal® Foil resistors from Vishay Foil Resistors, 100 resistors used.
-solid state output stage without capacitor in the signal path.
-external power supply to minimize the noise on the embedded preamp.
-aluminium and PMMA enclosure.
-power consumption 18W.
-DAC dimensions: height 110mm, width 360mm, depth 290mm.
-power supply dimensions: height 65mm, width 122mm, depth 180mm.
-weight: 4kg.
http://www.totaldac.com/D1-core-en.htm
Audio Analogue Anniversary series
Unread post #10 by Dr Pan K » Sat Jun 18, 2016 11:29 am
Designed by Airtech
Puccini and Maestro integrated amplifiers
