Qing Yi Lun G&W University Tsinghua T-2.2A Class A tube amplifier
Unread post #1 by Chris1967 » Sun Dec 12, 2021 2:26 pm
Μόλις χθες αγόρασα τον παραπάνω ενισχυτή ακουστικών.
Είναι μεγάλη ιστορία πως τον απέκτησα, αλλά είναι καινούργιος και άστρωτος βασικά.
Δυστυχώς δεν υπάρχουν πληροφορίες σε φόρα.
Τεχνικά χαρακτηριστικά δίνονται μονάχα σε ένα δύο site που τον πουλάνε.
Features:
a) the classical one common cathode line amplification, so that the shortest signal path.
b) The 3.2W power amplifier pentode do.
c) blue plastic package using high-end Japanese ALPS potentiometer.
d) imported 70 um thick copper thin double-sided printed circuit board.
e) The gold-plated solid copper knob.
f) using pure precious pear wood deluxe panel, laser engraving, unique artistic charm.
g) chassis with brushed stainless steel manufacturing.
h) EI-type core made ​​of imported high-quality power transformers, power of 80W.
i) The German gold FRAKO, such as fever, red WIMA capacitors.
j) slow start delay using high-voltage DC power to extend tube life.
k) imported iron core choke inductors to do filtering.
l) Power has a mute function, delay 20 seconds into working condition.
m) 60 ~ 600  can promote high-end headphones.
n) particularly suitable for use tube pre-amplifier circuit, the gain of about 20dB to promote any pure vacuum tube and transistor-level power amplifier can achieve after the very good results.
o) The tube model: inlet tube 12AT7 (ECC81); inlet tube 6P14 (EL84).
Specifications:
Input Sensitivity: 220mV
Frequency response: 16Hz ~ 117KHz (-1dB)
Harmonic Distortion: 0.05% (VRMS: 1V; 1KHz)
Signal to Noise Ratio: 101dB (output VRMS: 15V for the reference value)
Adapter headphone impedance: 60 ohm ~ 600 ohm high-end headphones
Static power consumption: about 36W
Tube: 12AT7 (ECC81); 6P14 (EL84).
Dimension: 380 × width 220 × depth 120mm high
Net weight: 7kg
Gross weight: 8.5kg
Power supply: 110/220V
Θα μπορούσε κάποιος να με διαφωτίσει πως ακριβώς λειτουργεί η τοπολογία των 12AT7 (ECC81) και 6P14 (EL84), διότι είμαι άσχετος από λάμπες, και αν θα με συμβουλεύατε για tube rolling (οκ το ξέρω ακόμα δεν τον πήρα και αρχίσαμε τα πειράγματα). Είναι προενισχύτρια η 12ΑΤ7 και οι δύο EL84 ενισχύτριες για το κάθε κανάλι?
Πάντως στις σύντομες ακροάσεις φαίνεται να έχει και ευφωνικότητα και έκταση και να μην λείπει η δύναμη, τουλάχιστον στα Sennheiser HD800 παίζει άψογα.
ΥΓ. Το μόνο που βρήκα από την κατασκευάστρια εταιρία είναι το παρακάτω λινκ αλλά δεν λέει τίποτα απλά ότι το νέο μοντέλο έχει ασημένια πρόσοψη και τοροιδή μετασχηματιστή. http://www.gwtsinghua.com/Article/produ ... 309/8.html
Re: Qing Yi Lun G&W University Tsinghua T-2.2A Class A tube amplifier
Unread post #2 by Dr Pan K » Sun Dec 12, 2021 3:14 pm
Λοιπόν, η ECC81 είναι διπλοτριοδος, χρησιμοποιούν μισή για κάθε κανάλι. Τίθενται δύο ζητήματα, τα δύο σκέλη να είναι ίδια για να έχεις ίδιο κέρδος και στα δύο κανάλια και δεύτερον, δημιουργείται cross talk ανάμεσα στα δύο κανάλια καθώς το ένα σκέλος επηρεάζει το άλλο.
Η El84 είναι μια μικρή πεντοδος, σαν μινιατούρα El34. Είναι μουσικότατη, το ίδιο και η οδηγήτρια. Αν ισχύει το swing των 15 Volt τότε στα 60 Ohm αποδίδει ένα μέγιστο 3.75 Watt, στα 600 Ohm το ενα δέκατο αυτού δλδ 0.375 Watt
Unread post #3 by Dr Pan K » Sun Dec 12, 2021 3:18 pm
Απ οτι βλέπω έχει ανόρθωση με διόδους ή γέφυρα, ο μετασχιματιστης όπως λένε είναι τετράγωνος ΕΙ και άρα επειδή είναι κοντά θα δημιουργεί κάποια EMI. Τα 70 μικρά πίστα είναι μια χαρά. Γενικά δείχνει τιμιος
Unread post #4 by Chris1967 » Sun Dec 12, 2021 3:23 pm
Οκ, εν τω μεταξύ δοκιμάζω και τα μαγνητοστατικά μου ακουστικά Fostex και HiFiMan, και βλέπω ότι τα πάει καλά.
Υπάρχει μια αίσθηση σκληρότητας όχι απο υπεροδήγηση μάλλον επειδή θέλει στρώσιμο.
Με τα HiFiMan EditionXX δένει τέλεια, και αυτό μου κάνει εντύπωση.
Δεν ισχύει ότι οιι λαμπάτοι ενισχυτές τα πάνε καλύτερα με ακουστικά υψηλής αντίστασης ενω με τα χαμηλής αδείαζουνε ?
Unread post #5 by Chris1967 » Sun Dec 12, 2021 3:24 pm
Dr Pan K wrote:Απ οτι βλέπω έχει ανόρθωση με διόδους ή γέφυρα, ο μετασχιματιστης όπως λένε είναι τετράγωνος ΕΙ και άρα επειδή είναι κοντά θα δημιουργεί κάποια EMI. Τα 70 μικρά πίστα είναι μια χαρά. Γενικά δείχνει τιμιος
Είναι ήσυχος δεν ακούω βόμβο ή φύσημα ακόμα και με το ποτενσιόμετρο τέρμα.
Unread post #6 by Dr Pan K » Sun Dec 12, 2021 3:30 pm
Από τις φωτο δεν βλέπω μετασχηματιστες εξόδου, μόνο ένα μικρό τσοκ και τον τροφοδοσίας, οπότε στην έξοδο πρέπει να έχει ένα πυκνωτή μετά τις λάμπες. Αλλιώς θέλει μέτρημα για DC.
Η ισχύς είναι κλάσμα του τετραγώνου της τάσης δια την αντίσταση. Στις λάμπες είναι και θέμα μετασχηματιστη εξόδου που εδώ δεν υπάρχει.
Unread post #7 by Chris1967 » Sun Dec 12, 2021 3:37 pm
Δηλαδή στα 190 ευρώ που τον αγόρασα είναι καλή αγορά? :mrgreen: είναι 7 κιλά μηχάνημα :lol:
Unread post #8 by Dr Pan K » Sun Dec 12, 2021 3:44 pm
Μια χαρά είναι, αν ήταν ευρωπαϊκός με πιο επιλεγμένα υλικά θα κόστιζε 1000. Να δούμε πόσο θα αντέξει και τι λέει από ήχο μόλις στρώσει
Unread post #9 by angpsi » Sun Dec 12, 2021 9:22 pm
Παρακολουθώ με ενδιαφέρον, κάποια στιγμή θα έρθω ν' ακούσω!
Unread post #10 by Dr Pan K » Mon Dec 13, 2021 8:27 am
Τι μαρκα ειναι οι λαμπες Χρηστο?
Return to “Ακουστικά”
